Pacer Question
Joe
06-04-2001 11:14:45
Could anyone tell me the seal # for the oil seal on the lever assembly for the governor on my pacer? It is a Novi governor,there are no #'s on the seal. The part # is 15 680a item #9 in the parts manual. Thanks,Joe
frank venasky
04-28-2004 15:46:22
 Re: Pacer Question in reply to Joe, 06-04-2001 11:14:45
does anyone kno where i can find parts to revibe my pacer.looking for carb rebuild kit,tune-up kit,thrmostat,fan belt,cinamun bopwl gasket.generally alot of parts.
Alberta Mike
06-04-2001 21:02:39
Joe, don't know the number but I've run into this same problem occasionally with all kinds of tractor seals. If you can get the old seal out without destroying it then take it to a good bearing house supply, they'll be able to match it up to something. If you can take the governor too, that's even better, then they can measure the shaft and the housing diameter into which the seal sits. If you can do that you're bound to find something.
