My workbull 204 is gutless
Mark
09-19-1998 23:46:30
The workbull 204 is guttless It has 3300 hours on it and when you tramp on the gas it spits and sputters like its half dead when you try to get it to idol it won't drop below 1100 Rpm
Any suggestions would be great
thanx
M. Smith
09-20-1998 14:23:26
 Re: My workbull 204 is gutless in reply to Mark, 09-19-1998 23:46:30
There are a lot of possibilities here, I would most likely start with the carburetor, and check the govenor linkage to make sure everyting there is in order. If the problem is in the carb., that is not to expensive, kit usually runs in the nieghborhood of about twenty bucks or less, for the Marvell carb. if it has the Carter carb the kit may be slightly higher. You also might want to check out you points in the distributor to make sure yhry are not burned badly, or that the gap has not closed up. While you are there also check the side play in the distibutor shaft to make sure that it is not excessive, this can cause problems withe running, but not likely to cause the high low idle rpm's you mentioned.
: The workbull 204 is guttless It has 3300 hours on it and when you tramp on the gas it spits and sputters like its half dead when you try to get it to idol it won't drop below 1100 Rpm
: Any suggestions would be great
: thanx
