Dual Clutch Allignment tool?? How or Where?
gerald
06-03-2001 22:00:31
Thinking ahead in putting my MF 35 back together, I was wondering what a guy does to get the clutch disks alligned. This is the first time I have had to deal with two discs as my tractor has. Is there someone who sells the tool or does anyone know a simple way of making one without a metal lathe as my book gives instructions for such? Thanks.. Gerald
Bob in CA
06-05-2001 21:42:05
 Re: Dual Clutch Allignment tool?? How or Where? in reply to gerald, 06-03-2001 22:00:31
Every time that I have split my tractors for clutch work, I have always,always replaced the transmission and PTO input shaft seals. This is the best time to do this and it only takes about an hour or less. The best part is that when the shafts are removed for seal replacement, I use the shafts to align the clutch and then I install them back in their place.
matt jones
06-10-2001 00:11:08
 Re: Re: Dual Clutch Allignment tool?? How or Where? in reply to Bob in CA, 06-05-2001 21:42:05
I agree with using transmission shaft. Should replace seals anyway. Also i have tried all the other ways nothing works as good.
JohnB
06-05-2001 06:43:47
There is a fellow that sells the dual clutch allignment tool on e-bay thats made from machined steel. I bought one for $12.00. Go to e-bay and search "massey ferguson clutch tool" and you will find it. He reguarly has them for sale.
gerald
06-05-2001 06:49:49
 Re: Re: Dual Clutch Allignment tool?? How or Where? in reply to JohnB, 06-05-2001 06:43:47
Thanks for the leads
Bill B
06-04-2001 19:51:55
Hi, I bought one from a guy on the net that makes them from wood.(under $20.00) Try [email protected] Bill
Paul in NM
06-04-2001 18:41:09
Most good auto parts stores carry the aligment tools made out of plastic. Very inexpensive. Look at your splines, count the groves and you can most likely find one that will work.
Paul
Bob
06-04-2001 11:13:21
I made one for my MF135 out of a piece of wooden dowel, and two pieces of plastic pipe. I glued it all together, and turned the necessary diameters on my lathe. Worked fine. It need to be a tight fit, or the alignment won't be close enough. Don't forget to pilot in the bearing on the crank end.
Bob
B.C.
06-05-2001 06:31:58
 Re: Re: Dual Clutch Allignment tool?? How or Where? in reply to Bob, 06-04-2001 11:13:21
If I remember right, the proper dimensions are in the I&T manual for Masseys. When I did ours, I did something similar to what you describe and it worked fine.
Pete Tatham
06-04-2001 00:06:51
Gerald, As you know, the two plates MUST be in alignment or you'll never get the tractor back together without damage. First I'd try the workshop foreman in your local MF dealership - he may be prepared to loan you an alignment tool if you leave a suitable deposit. Failing that I'd take the manual to the local machine shop and get a tool turned up, it's a very simple procedure for a machinist.
Pete
