MF85,PTO
Ray,IN
05-28-2001 18:45:57
I need help with repairing the PTO shifter. I think something is disconnected inside, because the shifter will shift into gnd pto and work, but not engine pto- it's like something came loose. I removed the inspection plate where the dipstick is and the mechanism is in the diff. it looks like, because I could'nt see any of it. Where/how do I find it and fix it? The only thing I've done is change the hy/tran fluid.
chuck
06-01-2001 05:53:03
 Re: MF85,PTO in reply to Ray,IN, 05-28-2001 18:45:57
The engine pto works of hydraulic pressure.if your power steering works then youll have to tear into the rear end to check the valve & actuator Mine quit also so I desided to use the 85 for other jobs rather than tackle the pto repair. The same hyd. pressure for the steering is used
for the pto actuation.
