Massey 135
larry
05-28-2001 04:34:52
I have a Massey 135 with the Perkins Gas engine. It runs great for about 15 minutes and then dies. After sitting for 30 minutes its ready to run again for another 15 minutes. It reminds me of a car with a bad fuel filter but I can't find one on the massey. any ideas?
thanks,
stacey
05-28-2001 15:41:52
 Re: Massey 135 in reply to larry, 05-28-2001 04:34:52
Check and see if you have good gas flow thru the sedement bowl. Could be clogged. also check and make sure the electric gas soliniod is working correctly. It's on the bottom of the carb.
Stacey
Smokey
05-28-2001 15:41:00
REmember to check the gauze strainer on the tap on the fuel tank. You will need to remove the fuel tap to do this at rear of the tank.
larry
06-23-2001 04:35:58
 Re: Re: Massey 135 in reply to Smokey, 05-28-2001 15:41:00
You hit it on the head, I changed the sediment bowl and 135 rus great. thanks again.
