Cooling water
John
05-27-2001 12:16:53
Hello,
Is it very bad for the engine if the cooling water has a brown colour, it seems to me like it has to be corrosion.
Thanks for the help, John
Smokey
05-27-2001 20:20:33
 Re: cooling water in reply to John, 05-27-2001 12:16:53
I noticed my MF135 bent axle which I purchased in 1997 has the same problem. A clean with a good radiator cleaning solution and refill with a good anti freeze/coolant solution is worth doing.
Before this tractor I had a MF135 straight axle for many years which was destroyed in a fire in 1997. Had to clean its radiator when I got it and it was still clean up to the time it was destroyed.
