MF 135 steering problem
jOHN SHOOK
05-26-2001 23:17:04
sure need some advice from expert advise on my recently bought MF135.Looks like USA. When I use it works but have to refill before each use. Also notice what looks like milky oil that rises to top when I fill it. Any help greatly appreciated. JJ
JJ
05-28-2001 07:51:24
 Re: MF 135 steering problem in reply to jOHN SHOOK , 05-26-2001 23:17:04
Thanks Jack, great info. JJ
Jack in NB
05-28-2001 04:41:44
Hi JJ -
Milky fluid could be water having got into the system in it's previous incarnation. Probably in through the reservoir filler plug, missing a gasket or o-ring.
You didn't mention any external fluid leaks, so the oil is disappearing internally, probably into the crankcase.
We've just replaced the front seal in the power steering pump on another model (MF 65) to correct this.
