Pto oil leak
Tony Silva
05-24-2001 23:24:31
1960 MF202, Leaking oil like crazy from the PTO shaft. I removed the three bolts that hold the retainer plate and pulled out the big round seal holder thing-a-mi-giggy. Do I just replace the felt seal and the neopreme seal in this seal holder? or do I need to go deeper?
How the heck do you remove the two seals from this seal holder?
Thanks all
Tony Silva
Lincoln CA.
Smokey
05-27-2001 20:26:19
 Re: pto oil leak in reply to Tony Silva, 05-24-2001 23:24:31
I have the same problem with a straight axle MF135. I also have a manual but I still am not sure what to do. Anyone with pictures?
Bob
05-26-2001 18:41:21
The seal assy is pressed into the retainer. Not hard to remove and replace, the part is cheap too!
If you do not have the facilites to remove and install, any auto machine shop can do easily.
Getting the pto shaft into the new sael correctly seems to be tricky. I just replaced mine, and it leaks like crazy!
Will update as I determine the problem.
wayne
05-25-2001 19:52:44
I replaced pto shaft seal on my '66 mf135 this past winter ,and if yours is like mine,it will be replaced with a complete assembly.It looked like a double seal with a felt dust ring enclosed in a "holder".If you don't have a manual consider getting one,I did.I hope I have helped. Goodluck!
