MF 35D- Loader Hyd Pump knock
gerald
05-24-2001 06:37:04
I noticed last night that when I stopped with my front bucket in the air my hydraulic pump was making a knocking noise. I thought it was the fan hitting something but it was definately comming from the pump. It is located in front of the radiator and drives off the crank. I dropped the bucket and it stopped. I raised it again and it did not make noise. I is full of fluid. I remember hearing it before. I believe it is the vain type of pump. Is this a concern and a tell tell sign that the pump is going bye bye?
Gerald (Norcal)
John
05-26-2001 06:00:03
 Re: MF 35D- Loader Hyd Pump knock in reply to gerald, 05-24-2001 06:37:04
I have the same problem with the internal pump on my MF50. It knocks when the 3pt is raised to the limit but stops if I push the lever forward a little bit. If you get any e-mail responses would you please forward them to me.
