MF 135 gas and hydrualics
Ryan
05-21-2001 11:24:36
Our MF 135 (gas) has developed a hydrualic problem. The lift will hardly lift the bush hog (or any other implement) off of the ground (with draft past the stop to where it clanges it will barely lift it off the ground... to the point that it still drags). It was suggested to me that there may be a filter or screen that is clogged and needs cleaned out. Is there such a screen and if so where is it and how can I get to it? Any other ideas on what the problem is (and how to fix it) would be greatly appreciated...
-Ryan Moore AKA Baradium
Fayette County, GA (Home to Inman Farm Heritage days, the largest antique tractor and engine show in the south eastern U.S.)
rick
05-24-2001 19:00:47
 Re: MF 135 gas and hydrualics in reply to Ryan, 05-21-2001 11:24:36
I had this problem on a MF165. There is a filter inside the case,but my problem turned out to be a broken pressure relief spring. hope this helps.
