MF135 Diesel
Graham Vayro
05-20-2001 02:22:40
I have just bought my MF135 D with a MF loader. At the rear, below the seat is a small dipstick. Is this oil the transmission, diff and Hydralic all in one?? Oil looks like sae30 and not like the red hydraulic fluid I am used to on other machines. What is the correct oil type please?
Bill B
05-22-2001 19:42:07
 Re: MF135 Diesel in reply to Graham Vayro, 05-20-2001 02:22:40
Hi, I use the oil Massey Ferguson sells. Its clear about the weight of 20 and costs about $16.00 for 2.5 gallons. Bill
Bob
05-22-2001 18:33:21
The 135 does not use mineral oil. You need a good quality tractor differential/hydraulic oil. I use Texaco TDH oil. Most farm, and all tractor dealers carry a suitable oil. This will be about 10-20 weight.
You need to obtain a service manual to see how to remove and clean the filter screen. NOTE be sure to replace the safety wire!
Bob
massey 135'er
05-22-2001 19:47:15
 Re: Re: MF135 Diesel in reply to Bob, 05-22-2001 18:33:21
Ohhhh crap....Could someone tell me what the safety wire is and its importance....By chance...is it connected to the hydraulic filter?? thanks
massey 135'er
05-22-2001 19:47:09
Bob
05-24-2001 16:49:17
 Re: Re: Re: MF135 Diesel in reply to massey 135'er, 05-22-2001 19:47:09
The safety wire secures the filter screen in place. It prevents the hold down bolt from unscrewing durein operation. If the filter lets go it really screws up the pump. You can remove the draft control and see the filter on top of the pump.
You really need a service manual.
Lee (MN)
05-20-2001 20:17:16
my 135 manual says 8 gallons of M-F permatron oil. I use universal tractor fluid in mine, never had a prob. good luck
C. T. in Oklahoma
05-20-2001 08:08:29
I have a MF35. The dipstick is for all three. A direct quote from my manual states:
"The mineral oil used in the hydraulic system also lubricates the transmission and differential gears and bearings. Two magnetic drain plugs have to be removed when changing oil. These plugs should be thoroughly cleaned before re-placing." It also states that it is essential that only a straight S.A.E. mineral gear oil be used in the system and that you should purchase it from your MF dealer, however, my lubricant section lists 8 U. S. gallons of S.A.E. 90.
