MF 35 Continental or Perkins Diesel
gerald
05-17-2001 12:50:47
I just read another post and saw there were also continental diesels. My serial no is 223074 which makes it a 1962 model MF 35. Was perkins the only diesels for this time and was the continental on the later models?? TIA Gerald
Chip
05-21-2001 06:46:34
 Re: MF 35 Continental or Perkins Diesel in reply to gerald, 05-17-2001 12:50:47
Perkins made the only 3 cylinder diesel for the 35's, if yours has 3 cylinders it's a Perkins, if it has 4 cylinders it's a standard.
Frank
05-19-2001 21:15:00
I own a MF 35 petrol. What points and plugs do I need for it. I live in New Zealand so details of New Zealand equivalents would be appreciated.
many thanks in anticipation
Jack in NB
05-20-2001 08:47:39
 Re: Re: MF 35 Continental or Perkins Diesel in reply to Frank, 05-19-2001 21:15:00
Hello Frank -
This site might help. Australian operation, has dealers in NZ.
http://www.bareco.com.au/files/massey/mfindex.htm
Rod Keirns
05-19-2001 12:29:32
There were at least some early 35 diesels equipped with four cylinder Standards (built by Standard Motors in England, I believe). The model 88 used a 276.5 cubic inch Continental 4 cylinder diesel. Those are more bigger, tho!
larry
05-20-2001 13:56:47
 Re: Re: MF 35 Continental or Perkins Diesel in reply to Rod Keirns, 05-19-2001 12:29:32
A guy i know has the 4 cylinder model and i have the same engine in a AC tractor. MF has no parts for this engine.
Rod Keirns
05-21-2001 11:15:18
 Re: Re: Re: MF 35 Continental or Perkins Diesel in reply to larry , 05-20-2001 13:56:47
Larry, is your Allis is an ED-40? On one of these boards someone made adapters to convert the original glow plugs over to an off-the-shelf pencil type.
Chip
05-18-2001 05:01:22
Can't say that I've heard that before, at least not in the MF-35. If you have a 3 cylinder diesel, it's a Perkins. And after 18 years with mine I can say it's the best.
Michael
05-18-2001 00:15:10
The four-cylinder models was earlier than the 3-cyl. Perkin's.
The 3-cyl is also appr. 5 hp stronger.
I have a -62 35 with a Perkins engine and it's running great.
