Tune up specs.MF 135 gas 1965
john jolliff
05-15-2001 20:40:05
This is dads old tractor its been years since it had a tune up he lost manual years ago. Does any one know the gap for plugs and timing for it. I just got new plugs at tsc they are champion d 16 same as the old ones.They are gaped at .25 to.030 now i know why it didnt run so good.thanks john jolliff
Jim/Mississippi
05-16-2001 22:12:40
 Re: tune up specs.MF 135 gas 1965 in reply to john jolliff, 05-15-2001 20:40:05
For the MF-135 gas tune up specs with the 4 cyl (continental) gas engine.
For continental 4 cylinder:
valve lash 0.013 inch hot-intake and exhaust
distributor point gap 0.022 inch
spark plug gap 0.025 inch
timing 6' b.t.d.c.@450 rpm
max advance 30' +/-2' b.t.d.c.@2000 rpm
This should get you goin real good with it. :-) :-) Jim
john jolliff
05-17-2001 15:22:03
 Re: Re: tune up specs.MF 135 gas 1965 in reply to Jim/Mississippi, 05-16-2001 22:12:40
thanks jim/mississippi / The old tractor will never be the same.Had to repair fuel tank so decided it also needed a tune up new plugs,wires points.put on a new muffler.now i need to get a new or used nose for it thanks again.john jolliff/OHIO
