Any tips on getting the front axle pivot pin out?
Tim
05-12-2001 13:42:15
Got the TO-35 running pretty good but I really need to do some front end work. Got the tractor supported so the weight is off the front end and took the bolt out that retains the pivot pin. The pin itself will not budge. I have beat on it in hopes of rotating it to brake it loose but it is well and truly stuck. Do I need to take the front axle support off the tractor and press the thing out? Thanks, Tim
Jim/Mississippi
05-16-2001 22:21:04
 Re: Any tips on getting the front axle pivot pin out? in reply to Tim, 05-12-2001 13:42:15
Tim, Have you had any luck yet?
Mine was so worn that it just pulled out with
my hand strength but I have heard that sometimes they are really stuck.
I've heard of using a slide hammer but I did not have any trouble with mine. I did have to
make a sleeve insert to take up the slack in my support (someone ran my MF with the bolt loose and the pin caused the support to wear quite a bit)
matt jones
05-13-2001 01:47:13
Tim ,
That is correct they will need to be pressed out, also have them polished once ya got them out.
P.S. may want to mark them there is a left and a right, they are not interchangeable.
