Tried this once B4 and you fellas told me to go get some numbers. So I went looking for numbers and got bunches, apparently they were big on putting parts numbers on everything.I mainly need some type of Model ID so I can get an IT manual and start to figure out how/if I can make it run. It's getting to be a serious need - Why, oh Why, can't women realize what a great deal you can get when you bring home pieces and boxes of pieces??? Anywho here's what I've got. It is a Massey with 4 cyl. engine with the plugs up on top. Has Pressure and amp gauge. 4 forward gears and reverse. Autolite starter # (M2 4072 50). Marvel/Schebler Carb. Narrow front 4.00x15 tires. 11.2x28 rears(marked 10x28 at rim) Number on top of trans plate 6333A and there is a 24 that doesn't appear to be part of first #. Number on lower left trans housing 9150-A there is also a 23 and an H on there. Screwed onto axle housing is a plate with #F16-8 Number on side of engine F400A418M and a 6-2?(looks like an 8). On the head is the Number F140A 30 and a plate with #B 182 is also screwed on head. I also have some digital pictures if anybody can explain to me how to get them in here. Thanks much in advance and remember = Ignorance is bliss and I'm grinnin' all the time!
