Massey ferguson 44 special
joe from ohio
05-06-2001 18:55:45
I would like a wiring digram of a massey ferguson 44 special. I would also like to know if anyone can help. The problem I'm having is that when I hook my battery up the temperature cable gets hot. I have replaced all the wiring and it still got the temperature cable hot so I removed the temperature cable then the oil line got hot. So I think there is a ground or there is something wrong in the wiring. If someone could help me with my problem. I really would appreciate it very much.
marlowe
05-06-2001 19:38:01
 Re: massey ferguson 44 special in reply to joe from ohio, 05-06-2001 18:55:45
is batt. hooked up + ground?? it might also be your engine is not grounded had this on a 33 once and the tamp. and oil cable were the grounds
joe from ohio
05-10-2001 18:43:41
 Re: Re: massey ferguson 44 special in reply to marlowe, 05-06-2001 19:38:01
To marlowe I would like to thank you for your information concerning my problem with my Massey ferguson 44 Special. I tried your suggestions and I did have a positive ground and my motor was grounded. However I checked my Ignition system out a little closer and discovered that my push button ignition switch had gotten hot and grounded internally to the instrument panel. So I replaced the switch and everything checks out good. I would just like to thank you again for all your help.
Joe from Ohio
