Rear mount grader blade on MF270
ronmo
05-03-2001 08:38:59
I just bought an 8 foot grader blade to use on my MF270. I need advice regarding using the draft control and/or position control when I am using the blade. Do I rely on one more than the other or do I use both?
Howard
05-07-2001 20:14:36
 Re: Rear mount grader blade on MF270 in reply to ronmo, 05-03-2001 08:38:59
I also have a MF270. On a blade you should use the position control (the lever with the square knob or the second knob in towards you from the fender on right side) The far lever (next to fender) is for draft control when plowing etc. Leave this handle allthe way back (towards rear of tractor) while using postion control. You will use position control most of time. Only time you use draft is when plowing or disking with mounted implement
