MF85 hydraulics drain
Ray,IN
05-02-2001 20:49:55
The simplest thing has stymied me. Where is the drain plug for the hydraulic system? There are no apparent drains on the bottom. I inherited the tractor, and the hyd. oil is contaminated with water, and I don't want to ruin the pump,power steering etc.
jeff
05-04-2001 22:44:10
 Re: MF85 hydraulics drain in reply to Ray,IN, 05-02-2001 20:49:55
Ray,
There are 3 drain plugs. One on the left side ( when sitting on it ) below the clutch pedal. One on the left behind the tool box. And on on back above the drawbar. I believe it takes 11 gallons to refill.
Jeff
Ray,IN
05-06-2001 19:43:22
 Re: Re: MF85 hydraulics drain in reply to jeff, 05-04-2001 22:44:10
Thank you Jeff. I think the YT site is the best for exchanging information. If ever I can be of help I'll try my best, just ask.
