Battery Overcharging
Don VD
05-01-2001 07:46:37
66' MF 135, Got my tractor last month and the
battery was shot so I went to TSC and got a new
one. Put it in and after running the tractor for 2
hours I noticed it had battery acid all over the
engine(wasted my new paint job), washed it off and
checked the water level in the battery, it looked
alright so I assumed they overfilled it at TSC.
Well so as to not ruin my engine cases new paint
job futher, I put a tee shirt around the battery
and ran it for a few hours. It was wet again. But
the battery wasn't even the slightest bit hot. On
the ampmeter on the dash it doesn't appear to be
overcharing, dead center between + -. Checked my
owners manual and the wiring diagram indicates it
has an alternator and regulator. I looked at the
alternator and its brand new, looks like the
dealer replaced it before I bought it. Is there
any way to turn down the charging level with the
regulator, what can I do.
Bob
05-02-2001 09:12:56
 Re: Battery Overcharging in reply to Don VD, 05-01-2001 07:46:37
It is certainly overcharging! It will ruin the battery, and the gernerator/alternator too.
First you have to determine if it has a gernerator or alternator. If it is a '66 it has a generator, unless it has been converted to an alternator. The gen is perfectly cylinderical, with a remotely mounted (under the dash) regulator. An alternator looks different, (like on a car), and most likely has an internal regulator. The regulator in either case is most probably the problem.
Let us know which system you have.
Don VD
05-03-2001 06:44:51
 Re: Re: Battery Overcharging in reply to Bob, 05-02-2001 09:12:56
It a generator, following an email, from another
forum member I found the regulator, and measured
the voltage across the battery when running and it
was over 14V. I tried adjusting the regulator
screw to get 13.6 - 13.9 V but its very non-linear
and jumps from 13 to 14 almost immediately with
just a very minor screw adjustment. I tried for an
hour and the best I could do was 13V. Any movement
of the screw past 13V and it drifts up to 14V,
Seems very fickle. The regulator and generator
look to be new. I guess I'll run it at 13V and
hope it doesn't drain the battery. Thanks for the
followup, if you have any other info I'd
appreciate it.
Bob
05-04-2001 18:45:21
 Re: Re: Re: Battery Overcharging in reply to Don VD, 05-03-2001 06:44:51
Does the regulator look new? It may be bad, also ALL the connections have to be CLEAN including where the regulator grounds. If the reg is used, I would pull it off, and carefully clean all the ralay contacts inside with 600 paper,a nd then clean with alcohol to remove the grit.
You need to measure the voltage with a digital meter, the analog's ae accurate enough.
