MF35 Transmission
Steve Clark in
04-27-2001 07:38:39
First let me say thanks.. I had my MF35 stuck in first gear and after reading the board I realized it was and easy fix ( took about two minutes ) but after removing the transmission filler bolt I noticed the transmission oil only filled about 1/4 of the bottom of the transmission. Next question is how do you check the transmission oil level? My MF35 service manual just says fill with 8 gallons of 80 weight mineral oil after a complete drain. I don't want to drain the whole thing just top it off. Thanks in advanced
Steve Clark
Ricky Hiers
01-04-2004 15:57:37
 Re: MF35 Transmission in reply to Steve Clark in Kansas , 04-27-2001 07:38:39
How do I find parts for a 1972 massey furgenson 35 industrial tractor? Transmission and clutch?
Chris C.
04-27-2001 11:56:00
There should be a dipstick on the right side cover plate (on the opposite side from the one with the pto lever)the trans & hyd.system share the same fluid. Be sure you don't use detergent type hyd. fluid it can cause jerky and erratic lift operation
