Massey 135 Trans
Randy Steep
04-24-2001 21:30:41
I have a Massey 135 diesel with amulti power trans. My problem is as tractor starts to warm up it sticks in gear when running. Sticks more when hot.I shut motor off and trans comes out of gear. Whats wrong.
Lee
04-27-2001 13:16:47
 Re: Massey 135 Trans in reply to Randy Steep, 04-24-2001 21:30:41
Believe it or not that's normal SOP for a Multi-power trans. Put the Multi-power in Low and that will release the pressure on the gearshift so you can shift. That's right out of my MF-165 manual. If you shift just as you push in the clutch and before the tractor stops moving it will work better, that's what I find on mine.
