My live pto is dead!!!
dustyhead43
04-21-2001 18:17:10
my problem is this. i just got the tractor and the live power is dead, the pto will operate only in the ground position, put it in the engine position and it just sets there. what i have done so far is, check to see if it turns by hand, it does, in free position it is free, in ground positon it is locked, in engine position it turns but only approximately 1/3 of a turn then it stops with a "thud". i have removed the hydrualic cover and checked the shaft it seems clear up to the tranny. heres where it gets weird, with the engine running you can turn the shaft either way and it just stops with the thud, i thought for sure gears would grind if i turned the shaft with the motor running. my question is now, why is the shaft not working properly and can i see what is wrong if i pull the steering wheel housing assembly off and drain the tranny fluid, and what do i look for????
any help will be of great help!
eddie
bob
04-22-2001 07:25:05
 Re: my live pto is dead!!! in reply to dustyhead43, 04-21-2001 18:17:10
what model you talking about
dustyhead43
04-22-2001 07:28:53
 Re: Re: my live pto is dead!!! in reply to bob, 04-22-2001 07:25:05
oh yeah guess that might help huh!!!
its a massey ferguson mf50 with the continental z134 egine
