Mf35 need help
randy
04-19-2001 18:15:04
when i push the left brake to aid in steering,instead of stopping the wheel it seems like all power goes to that wheel now.this just started two days ago.whats wrong?thanks for the help
WVMark
04-20-2001 19:48:20
 Re: mf35 need help in reply to randy, 04-19-2001 18:15:04
First Question, does your tractor have dif-lock, and is it by chance stuck engaged? If no to both, then I'd say you've lost an oil seal on the left wheel, soaked the brake shoes with oil, and really don't have a left brake. I can't imagine anything that could cause a transfer of power to the left wheel when the left brake pedal is depressed.
Tony Young
04-23-2001 11:46:01
 Re: Re: mf35 need help in reply to WVMark, 04-20-2001 19:48:20
I would go with the oil seal gone as nothing will make the power go to one wheel in this instance.
RANDY
04-23-2001 14:48:45
 Re: Re: Re: mf35 need help in reply to Tony Young, 04-23-2001 11:46:01
THE OIL SEAL GOT ME THINKING,SO I WALKED OUT AND CHECKED AND SHURE ENOUGH THE LITTLE LEVER YOU FLIP TO MAKE BOTH PEDALS ONE GOT FLIPED SO THAT WHEN YOU PUSH THE LEFT PEDAL YOU WERE REALY WERE PUSHING THE RIGHT ONE{THE FLIPPER WAS STUCK WAY UNDER SO PUSHING THE RIGHT PEDAL CAUSED NOTHING OUT OF THE ORINARY TO HAPPEN}SO THANKS FOR GETTING ME THINKING AGAIN,IT SEEMS LIKE THE SIMPLE DUMB PROBLEMS ARE THE HARDEST ONES TO FIX,THANKS FOR THE HELP
