Tachometer Drive on MF50
John
04-18-2001 05:55:22
My '58 MF50 has the mechanical drive tachometer. The tach works when I connect the shaft to an electric drill but the drive gear for the generator shaft is missing. The part number on the generator goes with the original equipment on an MHF50 so I'm not sure if it was scavanged by one of the previous owners. The shaft on this generator only sticks out a fraction of an inch and there does not seem to be any way to attach a drive gear. Can anyone tell me how this tach drive is supposed to be set up and where I might find this tiny gear. Any help will be greatly appreciated.
eddie
04-18-2001 18:49:57
 Re: Tachometer Drive on MF50 in reply to John, 04-18-2001 05:55:22
there is a small gear box type of arrangement that is held on the rear of the generator by two screws, the shaft coming out of the generator should be splined, this drove gears in the box to which the cable screws onto
John
04-19-2001 05:59:31
 Re: Re: Tachometer Drive on MF50 in reply to eddie, 04-18-2001 18:49:57
Thanks for your help. The splined generator shaft is what is missing from my setup. The generator was probably taken off another tractor.
eddie
04-19-2001 19:46:48
 Re: Re: Re: Tachometer Drive on MF50 in reply to John, 04-19-2001 05:59:31
actually due to a recent purchase i now have 2 generators off a mf50 that work and have the complete drive assy. where are you and would you be interested in a generator????
email me if you are interested.
