MF-135 transmission and rear end oil getting in engine pan
GEF
04-17-2001 23:22:19
A friends MF-135D seems to be pumping the rear end - transmission fluid into the engine pan. There are 2 pressure plugs under the hood just behind the engine or above the clutch. The right one has blown out and fluid squirts out this hole. After filling the rear end it takes about 5 minutes of running to pump the fluid into the engine and no fluid shows on the trans. dipstick. The engine oil dipstick will show about a 2 inch overfill. The fluid will drip out of the small drain hole at the bottom of the clutch. There are 2 remotes on this tractor. This was explained to me over the phone this evening so I hope you can understand what I am trying to say without getting to confused. Thanks for any replys. GEF
PIERCE
04-25-2001 16:33:39
 Re: MF-135 transmission and rear end oil getting in engine pan in reply to GEF, 04-17-2001 23:22:19
Is it a multi power??
gef
04-29-2001 23:27:09
 Re: Re: MF-135 transmission and rear end oil getting in engine pan in reply to PIERCE, 04-25-2001 16:33:39
yes it is, it is leaking around the shafts. I have received good information about this from Big Dean. The folks doing the repair work are still waitig for a manual which should be here Monday and I am sure they will have more questions when they get to taking it apart. Thanks gef
