Many Questions
Don H
04-17-2001 19:10:33
I have a MF 150 with a perkins diesel. Serial # is 9A47370. Am I correct to assume that it was built in Jan. 1969? The injector has an annoying diesel seep along the gasket between the top plate and the bottom 2/3rds of the injector. Is there an easy fix? The tractor runs like a top. The lift worked fine last summer mowing and raking hay. It has slowed now. It lifts as much weight and doesn't settle any faster than it did last summer. I can't tell any difference when the response control is placed in the slower or faster mode-lift speed is about the same. My IT manual showed an adjustment on the response control. While looking through the port where the adjustment is made I was unable to see an allen screw-just a small hole in the wall. Have I lost something? Big Dean? Thanks in advance.Don H
