Tiller?
Hawgee
09-08-1998 09:52:28
Hello, It is great to find this board as the locals are full of Deere's and MM's. JUst had a local show (Fall City,WA.) and only two MF's. Question. I bought a tiller from a local man soom years ago. Have been all the way thru it and replaced seals and drive chain. Adjusted slip clutch and before tractor pooped, it worked wonderful. Don't know who made it? It bolts directly to rear (4 bolts) over the PTO and and has lever for in and out of gear on side of gearbox. Works great but a little more work for the on and off. The man asked for $10 and all I had that day was a $20. I figured it was a sweet deal. I've had it on th MF 35 Utility and the guy I bought it from said he run it on an older Ford.
DaBrow
09-08-1998 17:02:34
 Re: Tiller? in reply to Hawgee, 09-08-1998 09:52:28
: Hello,
: It is great to find this board as the locals are full of Deere's and MM's. JUst had a local show (Fall City,WA.) and only two MF's.
: Question. I bought a tiller from a local man soom years ago. Have been all the way thru it and replaced seals and drive chain. Adjusted slip clutch and before tractor pooped, it worked wonderful. Don't know who made it? It bolts directly to rear (4 bolts) over the PTO and and has lever for in and out of gear on side of gearbox. Works great but a little more work for the on and off. The man asked for $10 and all I had that day was a $20. I figured it was a sweet deal. I've had it on th MF 35 Utility and the guy I bought it from said he run it on an older Ford.
A tiller for $20!! " ...sweet deal." An understatement to say the least. Maybe sameday.....
