General Questions
Heather and Jud
04-16-2001 13:31:35
Hi all,
We just purchased our first tractor...1976 MF 135. (Diesel) Wondering if any of you can give us any info you think is useful...also, some questions:
Does the tractor use heavy duty or light duty diesel engine oil?
What type of oil should I be using to lubricate any implements with chains (ie snowthrower)?
Also, any additional info would be great particularly what manual issues we should keep our eyes out for...we have the IT Shop Manual but it doesn't seem to cover regular maintenance schedules and info, just repairs... Thank you!
Alexander
04-23-2001 22:10:20
 Re: General Questions in reply to Heather and Judy, 04-16-2001 13:31:35
But they didn't make 135's in 1976.
Heather and Judy
04-24-2001 13:30:23
 Re: Re: General Questions in reply to Alexander, 04-23-2001 22:10:20
We were told it was a 1976 but have heard otherwise from more than one person =)...any idea how to verify what year it actually is???
David
04-19-2001 19:38:47
I use Shell Rotella 15w40. It is a good oil and not too expensive. On all of my equipment chains, I use John Deere chain and bar lubricant. It is pricey but it lasts a long time. A standard owners manual covers the basic service info and if you can find a dealers part and service manual that is a big help. I change the oil and grease everything every 50 hours. I think it pays in the long run. Hope this helps, David.
Bob
04-16-2001 18:01:36
You have a great tractor!
I use Chevron Delo, approved for diesels, works fine. Be sure to change the oil filter too! If you have the older cartridge type filter, you can get the new filter mount for the spin-on type, for about $20.00, much easier and cleaner to change the filter.
I don't really know about the chain drives, maybe someone else here does..
As for the maintenance, I would purchase a copy of the factory owners manual. It has all the info.
As a rule, you should change the transmission/differential/hydraulic oil. There are two drain plugs on the bottom. You will need two fairly large containers, as the capacity is about 10 gallons if memory serves. Purchase enough of a good quality tractor differential/hydraulic oil. Note that plain hydraulic oil will not work!
Also you need to lubricate all the grease fittings with a moly type grease.
As for the fuel filter(s), you may have one or two, this is involved. You will NEED to follow the manual, and be very clean to do this, as thge injection system must be bleed of air after changing the fuel filter.
Good Luck,
Bob
Dan
04-17-2001 09:30:02
 Re: Re: General Questions in reply to Bob, 04-16-2001 18:01:36
Bob,
Could you recommend a source for the spin-on oil filter adaptor for the 135? Thanks.
Dan
Jim/Mississippi
04-17-2001 04:15:36
Bob has given some excellent tips!...
I wanted to add a tip of my own about coolant...
- I'd drain the coolant and install a new thermostat. I'd refill with same coolant if it is in good shape or install fresh coolant (using distilled water with new antifreeze).
When you get your manuals (check out this site here!), I'd reccommend getting a complete set of factory manuals(Parts book, Service book & Operators manual) they are nice to have.
