Engineering job
jamal kedkad
04-18-1998 10:34:17
agr.mechanical engineer, 5 years production lines manager in MF factory, experience head to toe in MF200-300 series tractors,
wanna hire me please call 303-471-9694
johnny
04-30-1998 19:58:45
 Re: engineering job in reply to jamal kedkad, 04-18-1998 10:34:17
: agr.mechanical engineer, 5 years production lines manager in MF factory, experience head to toe in MF200-300 series tractors,
: wanna hire me please call 303-471-9694
I dont have a job, but i do have a question I would like to ask you. I have a mf165 with mf 236 front end loader. The power steering pump is bad on my tractor and I am thinking of trying to run hydraulic lines from the output port of my front loader control valve to the power steering cylinder and run the power steering off of the same pump as my front end loader. Will this work.
Bill Hildebrand
01-23-1999 08:50:40
 Re: Re: engineering job in reply to johnny, 04-30-1998 19:58:45
I am an executive recruiter specializing in Sales and Engineer RECRUITMENT. Please give me a call if I may be of service.
Thanks,
Bill Executive Search Ltd.
513-874-6901
[email protected]
fax 513-870-6348
Gerald
05-04-1998 22:58:40
: : agr.mechanical engineer, 5 years production lines manager in MF factory, experience head to toe in MF200-300 series tractors,
: : wanna hire me please call 303-471-9694
: I dont have a job, but i do have a question I would like to ask you. I have a mf165 with mf 236 front end loader. The power steering pump is bad on my tractor and I am thinking of trying to run hydraulic lines from the output port of my front loader control valve to the power steering cylinder and run the power steering off of the same pump as my front end loader. Will this work.
JD does that in the 3010,3020,4010,4020 and later tractors. They protect power to the steering with a priority flow control valve so the power steering always has power even when other things are taking power hydraulic. I don't know how much flow the power steering requires. These JD tractors have 18 to 21 gpm engine driven pumps to supply power steering, power brakes, power differential lock, three point, and external cylinders.
johnny
05-05-1998 20:12:55
 Re: Re: Re: engineering job in reply to Gerald, 05-04-1998 22:58:40
: : : agr.mechanical engineer, 5 years production lines manager in MF factory, experience head to toe in MF200-300 series tractors,
: : : wanna hire me please call 303-471-9694
: : I dont have a job, but i do have a question I would like to ask you. I have a mf165 with mf 236 front end loader. The power steering pump is bad on my tractor and I am thinking of trying to run hydraulic lines from the output port of my front loader control valve to the power steering cylinder and run the power steering off of the same pump as my front end loader. Will this work.
: thanks. I talked to a hydraulics shop and they said that they could build a regulator and valve for about $180, but I think I will go ahead and buy the regular power steering pump as I can get one for about $300 and then it will be original. Thanks again. jm : : : :
: JD does that in the 3010,3020,4010,4020 and later tractors. They protect power to the steering with a priority flow control valve so the power steering always has power even when other things are taking power hydraulic. I don't know how much flow the power steering requires. These JD tractors have 18 to 21 gpm engine driven pumps to supply power steering, power brakes, power differential lock, three point, and external cylinders.
