Source Hydraulic fluid for large MFs
chuck
04-04-2001 15:34:11
I have 2 large 1135/1105 MF tractors that hold
25+ gallons each & use 2 hyd. filters each.As everyone knows MF stuff is expensive so I would
like to know of a type hyd. fluid for these that
can be found at tractor supply or auto parts store A source of aftermarket filters would be very
helpful also
Nogrimace
04-08-2001 06:15:13
 Re: Source Hydraulic fluid for large MFs in reply to chuck, 04-04-2001 15:34:11
Chuck
I get my oil from cardwell distributors. It is AMOCO 1000. It goes for 25.00 for 5 gals. I have seen the Tractor hydraulic fluid in Sams club and have given it some thought, My MF-40 leaks a bit out of some hoses to the backhoe, but the cost of replacing the steel high pressure hoses hasn't warrented me to do so vs the cost of the fluid. I guess I had better check the fluid at Sams club. There is a Gentleman that retired from Massey as a mechanic, check the Archives and look for my questions about replacing the brake linnings just a month ago. This will give you his email address. He was very informed and could probably answer you question. I have his name, his email address and a web is listed under, Big Deans Massey Furgesons tips. Good luck.
Tyler(WA)
04-05-2001 10:28:08
I get "Tractor Hydraulic Fluid" in 5 gal. pails at SAM's Club, for about $14/pail. It's high quality and runs fine in my MF-2135 and my friend's fleet of heavy equipment. He uses it in excavators, dozers and loaders with no trouble over many years of business. Compared to the same product at over $36/pail at the tractor supply store, SAM's membership dues are paid for in one trip.
Best deal going.
Sid Miller
04-05-2001 09:38:54
I use hydraulic oil and filters in my 1105 that I get at the local NAPA store.Have since the tractor was new in 1976.
LANCE
04-04-2001 21:04:22
I WOULD NOT HAVE ANY PROBLEM USING HYD. FLUID OTHER THEN M.F. ANY MAJOR OIL COMPANEYS TRACTOR HYD. FLUID IS OK TO USE.JUST BE SURE IT IS TRACTOR HYD. FLUID AND NOT JUST HYD. FLUID.MOST BRANDS SAY WHAT O.E.M. FLUIDS THEY REPLACE.
GOOD LUCK LANCE
joe
04-04-2001 18:47:43
this i would not recomend this from personal loss one trans. an a diff. the cost of the right oil is cheep to a trans or diff. got some fite all oil from a after market store the pail said it matched every thing from massey to god knows what 100 hours latter the trans in one went 145 hours the diff. went was not high e.p ond not right for the hyd. but its your tractor so i will sayuse what you want but these co. spend millions on testing this stuff
