Disc harrows on a 135
kcurley
04-03-2001 07:55:42
I have a gas 135, and have a chance to buy a 28 plate hydraulic mounted disc harrows. I think this is too large for this tractor, does anyone know?
Hal
04-05-2001 08:33:53
 Re: Disc harrows on a 135 in reply to kcurley, 04-03-2001 07:55:42
I have used a MF 3-pt disc with 24 blades on a 35, it pulls easy. You should be ok with the 28-blades; you can always hold it up in soft ground. Is it an MF disc with 6.5" between blades? My neighbor has one with 28 blades and pulls it with a 135.
timbo
04-03-2001 13:07:00
Without knowing the disk size I would say that it is little on the large side. If it is a smoothing harrow with about 16 inch discs you may can handle it but with 20 inch notched discs about 18 to 20 discs is enough.
