MF35X Loader Series 7 Part Drawing needed
Tim Thirst, Nor
03-28-2001 03:05:37
Re my previous message, I am still unable to locate a front mounting plate which supports the forward end of the two compression struts, which go from the loader posts to the front of the tractor. The plate mounts underneath the radiator. Although it is pictured in the instructions, has anyone got a part drawing so that I can make one up please.
gavin
03-28-2001 14:33:00
 Re: MF35X Loader Series 7 Part Drawing needed in reply to Tim Thirst, Norfolk England, 03-28-2001 03:05:37
I advertised for a loader for a 35 in the anglia freeads. One that I was offered was a MF made loader that fitted in part to the front mounting point. Ididnt go for it cos it wouldnt fit a 65 too like the MF735. It was somewhere near Wisbech. Another ad might find it.
Gavin
Tim Thirst
03-29-2001 10:28:30
 Re: Re: MF35X Loader Series 7 Part Drawing needed in reply to gavin, 03-28-2001 14:33:00
This came with the tractor in parts, but this plate was missing. I could draw one up, the mounting holes (5) are OK as a piece of tracing paper rubbed over it sufficed for the dimensions, but would like to know the correct placing of the bearings - or even better still find the plate:-)))
I might try the yellow ads. If I didnt need one, you can be sure there would be a column full of them for sale!
Thanks
Tim
