MF 165 Looks heavy-duty
Stan
03-26-2001 18:56:15
I have a MF165 (or so it says on emblem on one side of hood)s/n 9A 74088. It has non-adjustable front axle (about 3"x 5" tube) 7.5 x 16 front tires, and 16.9 x 25 rears. Non-adjustable rears also, with heavy-looking cast centers/weights? Has dish type rear fenders. None of the 165's I've seen look like this one. Can anyone tell me anything about this, such as industrial model maybe? Has no remote hyd. , no front pump, seems to never had a loader on it. 6-speed, no multi-power. Also, has anyone here had any experience replacing the bushings on the steering shaft in the front casting? Any special tricks I should know before I start? Thanks
It's me again Margarite!(Stan)
03-27-2001 06:56:51
 Re: MF 165 Looks heavy-duty in reply to Stan, 03-26-2001 18:56:15
I used some oven-cleaner to clean the engine and front-end, had some fuel leaks which had contributed to lots of grime and crusty crud over the years, underneath all that I found some yellow paint. The tractor was MF red and grey, but seems that the engine and front castings, pwr. steering, etc. was yellow under the grey. Where do I find numbers for Industrial models? By the way, oven-cleaner does fantastic job of getting old crud off tractors. Wouldn't want to put it on good paint though.
