MF 135 coil problem
Glenn Deckert
03-19-2001 22:43:01
To J.Tyler--Thanks for the help! Your logical approach was excellant guidance for diagnosing my problem (see posting on #/15--sparks arcing across top of coil). I checked the plug wires first (since that was the easiest to do) and found that the plug wire to the first cylinder had become disconnected from its end where it plugs into the distributor cap. The only thing keeping the plug wire in place was the rubber boot. I fished out the wire end with a needle-nose plier and re-crimped to the end of the plug wire --problem solved!! Thanks again. Glenn
Tyler(WA)
03-20-2001 06:43:25
 Re: MF 135 coil problem in reply to Glenn Deckert, 03-19-2001 22:43:01
Glad you found the problem. Thanks for the update.
