Power Steering Fluid
Don H
03-19-2001 19:13:09
I have a 1970 MF 150 and am about to replace the filter in the powersteering pump. What type fluid should I refill with? I searched the archives and there was an about an equal split between 1129 (tranny fluid) and Dextron II. Thanks in advance.
Big Jim
03-22-2001 13:26:11
 Re: Power Steering Fluid in reply to Don H, 03-19-2001 19:13:09
Don,
Dextron II or Dextron III ATF is the recommended PS fluid for most Massey's. However I think you could use just about any hydraulic fluid or even engine oil and it would also work good. Their not too picky about fluid, just put clean fluid in.
Ray,IN
03-20-2001 19:42:28
What did the MF dealer say?
LANCE
03-19-2001 19:51:14
ANY GOOD TRACTOR HYD. FLUID WILL WORK FINE.I WOULD NOT USE A.T.F. GOOD LUCK LANCE
