Water pump problem?
kenny
03-17-2001 05:53:05
my water pump is only dumping a small stream of water back into the radiator maybe the size of a pencil. Radiator is not plugged. The tractor is staying cool at idle. I do not want to put a load on it with only this much flow. Took the whole water pump housing off and it spins very free it does not leak out of the weep hole. Is this a normal amout of water flow or could is my thermostat possible stuck shut?
BlueLight
03-17-2001 06:36:15
 Re: water pump problem? in reply to kenny, 03-17-2001 05:53:05
Could be the thermostat. But if it is you
would also get overheating.
The only thing else I can think of are loose
belt or corroded impellers.
You might want to clean out the jackets with CLR while your at it. Make sure you flush out with
clean water after sitting for awhile. Blue.
