Restoring gas tank on TO-35
Tony
03-11-2001 20:48:50
Greetings, I have recently removed that gas tank on my to35 only to find rust particles and debris in there. I want to clean it out and and reseal it with either paint or some sealant. Any advice in this project?
Stan
03-12-2001 15:35:28
 Re: Restoring gas tank on TO-35 in reply to Tony, 03-11-2001 20:48:50
If your tank isn't leaking, the fixes from Jerry and Rick sound good. I've fixed 2 leaking gas tanks with "Kreem" brand gas tank sealer. Got it from a motorcycle shop. They seal Harley tanks with it. It's worked very well for me both times.
Jerry in Id.
03-11-2001 22:37:44
Tony. Had the same problem with my TO-35 gas tank. Took it to the radiator shop, had them hot tank it and then coated with gas tank sealer. Best thing I have done. No more rusty gas or cloged filters. Good luck
Tony
03-12-2001 20:26:17
 Re: Re: Restoring gas tank on TO-35 in reply to Jerry in Id., 03-11-2001 22:37:44
Thanks for the info guys. I got some acetone, several screws and bolts and threw it all in the tank and shook it like crazy. I was very surprised at all the crud that came out. I will do it a few more times. The tank is in pretty good condition. Jerry, what is the gas tank sealer you used and where can I get it. I called several autoparts stores and they have no idea. Thanks again guys from the Lone Star State.
Jerry in Id.
03-13-2001 20:04:57
 Re: Re: Re: Restoring gas tank on TO-35 in reply to Tony, 03-12-2001 20:26:17
Tony. Your question surprizes me I was under the impression that the coating material was available everywhere. I bought mine through Hinkleys automotive magazine but I also know that it is avaliable through eastwood(www.eastwoodcompany.com).If you are still having troubles check with your local radiator shop.
Rick(ont)
03-12-2001 13:49:52
Had the same problem with my 35 Diesel. It plugged up the filter with dirt and would't run. Took the tank off and sent to a rad shop and they steamed it out.Came back shiney. I just installed and filled it right up with fuel to prevent further rust.Replaced all filters and its run great ever sinse.
