Aircleaner MF 35 diesel
Rowland Rippy
09-03-1998 11:17:19
Need an aircleaner for my 62 MF 35. It is US made and has the Perkins 3 cylinder diesel. The cleaner is shaped like a toaster. Mine must have rusted internally and the previous owner hollowed out the internals.
Fireball Melton
09-16-1998 21:19:20
 Re: Aircleaner MF 35 diesel in reply to Rowland Rippy, 09-03-1998 11:17:19
What you need to do is put on a MF 135 dry type filter assy. on it! You cac cut the mounting brk off the old one and weld a pice of metal bent in a 90 degree angle with the bolt patern drilled inn it. Hook it up tp the AC hose after cutting bracket to see how and where you need to weld the pice that you made! Later Fireball
