MF 180
porky
03-09-2001 04:19:22
We have had this 180 with a perkins diesel for years never has started right.It runs great after it starts.So we decided it was time to do something about it.We had the injectors and the pump rebuilt new transfer pump rings bearings and had the head rebuilt and still will not start right.A little shot of either and it starts right up and runs great.Is this just typical for perkins or what.When it is 50 degrees or above it fires up no problem THANKS PORKY
mick
03-30-2001 16:43:45
 Re: MF 180 in reply to porky, 03-09-2001 04:19:22
i have a 180 with a block heater. it starts right up in below 0 weather if the heater is plugged in,
carl in nc
03-10-2001 20:26:33
I have a 1135 with a 364 cu. perkins 6 cyl. and with good batteries it will start down to 10 degrees without a block heater or ether. lots of smoke for a few minutes, but it will crank.
timbo
03-09-2001 13:40:18
I would check the compression and see if all the cylinders have close to the same compression. Also check the injection timing.
Bill
03-09-2001 06:06:42
Porky:
I have a 1973 MF-165 rowcrop diesel with the Perkins AD4-303 engine (2900 hrs since new). I live in New England and use a block heater to start when the temperature is lower than 40 degrees. She'll start at lower temperature, but not easily. I'd suggest the block heater to save your starter motor.
