MF35 double clutch
Michael
03-07-2001 23:55:28
I have a MF35-61 Perkins 3-cyl with a single clutch.
Is it possible to change that clutch to a double or is it so much work that it is not worth it?
I would also like to know how to adjust the free-play on the clutch.
Thyge
03-08-2001 05:46:39
 Re: MF35 double clutch in reply to Michael, 03-07-2001 23:55:28
It is not just the clutch which must be changed.
The dual clutch version also has two separate concentric driveshafts going into the transmission.
The easiest way to convert is to swap the entire rear end with one from a tractor with a blown engine. (or rebuild that one instead)
Thyge
Taageskov
Denmark
Michael
03-08-2001 22:44:37
 Re: Re: MF35 double clutch in reply to Thyge, 03-08-2001 05:46:39
Thank's Thyge
It was what i expected but I did not really know.
Thyge
03-09-2001 06:48:45
 Re: Re: Re: MF35 double clutch in reply to Michael, 03-08-2001 22:44:37
To adjust the clutch, take off the access plate under the flywheel housing. You will find the adjusting bolts there. Remember to adjust all three bolts. You can either do it by ear, like I did, or look in the manual for clearances.
Good luck
Thyge
Taageskov
Denmark
