Power steering actuating linkage doesn't match book
Rick
03-05-2001 20:43:32
Trying to get my 165 steering cylinder to help out. Pulled out the manual to follow adjustment instructions and found that the picture and instructions don't match the machine. The cylinder is the same, but the actuating arm is different. There is no adjusting sleeve aka turnbuckle, the valve link is direct. The actuating arm has no "adjusting pin (2)". The tractor is one of the early models. Anyone ever seen this version?
Big Dean
03-06-2001 15:34:59
 Re: Power steering actuating linkage doesn't match book in reply to Rick, 03-05-2001 20:43:32
I have only saw two different steering control valve adjusting link the one with the turnbuckle
And one with threads on the actuator end of the link it has a nut then a square piece with a pin that goes in the actuator arm and another nut. You move the square in or out with the nuts to get the right length .if I can be of further help E-mail me
