Glass bowl on Perkins Fuel filter
Jack in CA
03-05-2001 16:20:22
Anyone know where I can find a replacement glass bowl for the fuel filter on my MF30B Perkins engine - or what a guy could use as a replacement?
BlueLight
03-06-2001 14:25:27
 Re: Glass bowl on Perkins Fuel filter in reply to Jack in CA, 03-05-2001 16:20:22
These bowls were very common on outside house fuel oil tanks before they were replaced by
the metal ones that have the same principle. Check out the scrap yards and look at the
old cars and machines with stationary engines.
A point on glass filters, make sure it has
the small ceramic filter that is being retained by the spring. You should be able to see this thru the glass. The filter was sometimes lost and
people used it anyway, without the filter it's
just a sediment bowl.
Blue.
Bill
03-06-2001 14:39:31
 Re: Re: Glass bowl on Perkins Fuel filter in reply to BlueLight, 03-06-2001 14:25:27
That's good information. I have not seen a filter.
Bill Stanley
LANCE
03-05-2001 19:20:23
JACK THIS GLASS BOWL IS A VARY COMMEN PART AND IS USED ON LOTS OF MAKES AND MODELS OF TRACTORS.SOME TIMES YOU CAN PUT A SHORTER 1/4 BOLT IN THE CENTER OF THE FUEL FILTER AND NOT USE THE GLASS BOWL.I WOULD THINK YOU COULD FIND ONE AT ANY TRACTOR DEALER.THIS IS A CAV FILTER SYSTEM. GOOD LUCK LANCE
Bill
03-05-2001 17:05:13
A 1949 Ford flat head eight car had a similar filter with a glass bowl. Wonder if there are any 49 Fords left in the junkyards.
Bill Stanley
