65 trouble
Sid Miller
03-05-2001 06:42:27
A friend has a 65 that runs fine when idling,but when the throttle is opened the engine stalls.This is all the information I have right now.Any suggestions on what might be the trouble will be much appreciated.
Pat
03-05-2001 17:27:34
 Re: 65 trouble in reply to Sid Miller, 03-05-2001 06:42:27
I had the same problem (I assume its a Continental G176 gas model). Can he prevent stalling by choking it when he throttles up? If so, try adjusting the high speed mixture on the carb. He may also have to take the carb apart and give it a good soak.
lance
03-05-2001 15:58:57
check the wire mesh in the oil bath air cleaner.some times they get vary dirty and the engine will not get enough air.this is a vary commen problem in the old tractors.good luck lance
