Need help with Perkins AD4-203 rebuild
Jim Equitz
02-24-2001 06:13:40
I was rebuilding my Perkins AD4-203 and found a cracked cylinder. I can buy a kit that contains 4 new sleeves, pistons & rings. Problem is they make two kits. One for cast iron sleeves and one for chrome sleeves. How do I know which one I need? The only discription for each is one has a .040 disc flange and the other has a .150 disk flange. Can any one tell me what this means?
Thanks
LANCE
02-24-2001 12:22:13
 Re: Need help with Perkins AD4-203 rebuild in reply to Jim Equitz, 02-24-2001 06:13:40
IS THIS ENGINE IN A MF TRACTOR.I WOULD THINK IF YOU HAVE A CRACKED SLEEVE YOU HAVE CAST IRON SLEEVES.THE .040 AND .150 IS THE THICKNESS OF THE TOP SHOULDER OF THE CYCLINDER SLEEVE.I THINK THE .150 IS CAST IRON.I HAVE NEVER HAD A CHROME SLEEVE CRACK.MOST OF THE NEWER ENGINES SUCH AS IN THE MF165 HAVE CAST IRON SLEEVES.BE SURE WHEN YOU INSTALL NEW SLEEVES THEY FIT SNUG OR YOU MAY WANT TO USE LOCKTIGHT SLEEVE RETAINER.GOOD LUCK LANCE
