MF-35 Delux
proper gearbox lube
John, Macon, MS
02-21-2001 09:45:10
I have just come into posession of a 1963 MF-35 Delux. I changed the transmission/hydraulic system lube. I put in tractor hydraulic fluid. Did I do right? If not, what should go in there?
Rick(ont)
02-26-2001 18:07:05
 Re: MF-35 Delux - proper gearbox lube in reply to John, Macon, MS, 02-21-2001 09:45:10
According to my MF service manual that I have for my 63 35 the oil used to lubricate the trans and differential is SAE.90 for temperatures above 50 F. and SAE80 for temperatures below 50 F. Capacity of these combined units is 8 US gallons.
timbo
02-21-2001 10:29:40
The MF 35 takes 8 gallons of MF spec. 1103 transmission and hydraulic oil. Look on the cans and see if the oil you put in matches these specs.
