Installation of left right plows on Pony
Ray
02-14-2001 20:03:02
I have a 50 Pony that has hydraulic and left and right ground plows. I know how to hook up front part of plows to draw bar, but am unsure how to hook up rear of plows. It has 2 hand levers that I know are able to hold one plow up with, while other is in ground. Can anyone help me on how to hook it up or have pictures of the rear of a Pony showing plows attached.
Robert
02-19-2001 07:17:45
 Re: Installation of left right plows on Pony in reply to Ray, 02-14-2001 20:03:02
I assume it is the same as my Pacer to which it is almost identical, especially since you have the hydraulic cylinder. You have two little arms that extend straight out the back of the tractor off the pipe that pivots when you apply pressure with the cylinder. To these two arms you attach another piece of steel that makes them protrude even further out the back of the tractor over the top of the plow that you have now mounted to the drawbar by turning the drawbar around backward so that it is under the belly of the tractor. At the end of those arms a notch is cut. You hook a chain into the notch and the chain has a ball of steel on the end of it that drops down through a loop of steel on the arm of the plow. When you lift the arm the ball raises the arm. As unlikely as this sounds it is suprisingly effective. The weight of the moldboard drops the plow into the ground (your points have to be good) and if you want to adjsut the plow upwards you just apply a little hydraulic pressure and bring the steel ball up so it hits the ring. Otherwise you can just leave the plow to float and if your points are good she'll bite at just the right depth. I'd send you a picture but I don't know how to mount one on the internet.
