MF 85 Generator Problem
WM Smith
02-13-2001 17:11:06
Battery doesn't seem to be charging when running. Checked voltage at battery when running. It read 12 volts. Shouldn't it be higher? I did have the generator and regulator checked and was told that they were OK. Perhaps I need to repolarize the generator. How should this be done? Any suggestions?
WM Smith(NB,Canada)
02-18-2001 05:05:15
 Re: MF 85 Generator Problem in reply to WM Smith, 02-13-2001 17:11:06
Thanks guys. I will check at higher revs. I did put a voltmeter accrossed the generator terminals at a medium idle and got nothing at all. Is it shot?
Tyler(WA)
02-15-2001 09:57:31
Generators don't charge untill the RPM is rather high. You shouldn't expect to see it charging at idle. Rev the engine up and see if it puts out then.
Ray,IN
02-13-2001 19:50:12
I polarize the generator by quickly shorting the field terminal and the battery terminal on the regulator. Just an instantious touch works, prolonged contact destroys the regulator and or generator.Normal voltage when charging is 12.5V to 14.5V depending on state of charge of the battery.
Bill (NC)
02-13-2001 22:23:03
 Re: Re: MF 85 Generator Problem in reply to Ray,IN, 02-13-2001 19:50:12
I think the polarization is supposed to be done with the field wire disconnected from the regulator.
Bill Stanley
