FE-35 Secondary Fuel Filter
Craig New Zeala
02-11-2001 19:04:33
Hi team,
I recently had to bleed my 23C Diesel and assumed that the hex nuts on top and towards the front of the primary and secondary filters were the bleed screws. The primary went okay - it loosened and I got some air to bubble out before diesel started flowing. However on the secondary filter the nut just turned and turned and never seemed to loosen or tighten (just light resistance). I got no air or diesel out so could not bleed from this filter. I continued on and bleed from one of the injectors and then the machine fired up okay. Any thoughts on this secondary filter screw - is it the bleed screw and surely its not supposed to just turn and turn like that?.
Rex, Darwin Australia
02-13-2001 02:36:16
 Re: FE-35 Secondary Fuel Filter in reply to Craig New Zealand, 02-11-2001 19:04:33
Craig, the thread seems to be stripped? Probably is. Is there any leaks now that you have it going? You may have to do a repair on the thread and seal it off as it could leak or suck air from a dodgy fitting.
Good luck, Rexexkiwi
