Head Stud Installation
Brandon
02-11-2003 17:16:36
What is the best way to put studs in a G block? I am putting new ones in, and I'd rather not put the pipe wrench on them like the old ones had been done when I took them out. Thanks for the help.
Lee
02-11-2003 21:56:58
 Re: Head Stud Installation in reply to Brandon, 02-11-2003 17:16:36
If you'll chase those threads with a tap and die set you can put them in by hand. Just be sure to trial mount the head on there to be sure you didn't put them in too deep to leave you enough threads on the working end. I sure wish I had!!
John D
02-11-2003 17:39:30
Brandon, go to an auto parts store and buy a stud bolt driver, it will fit a 1/2 drive socket and wont mark up the stud bolt.
BJ
02-11-2003 17:52:45
 Re: Re: Head Stud Installation in reply to John D, 02-11-2003 17:39:30
Another suggestion would be to put double nuts on the opposite end and tighten them against each other and turn the studs in that way
