2140 clutch
david
02-11-2003 12:56:33
The clutch in a 2140 JD wouldnt work this year so we changed the slave cylinder and still nothing. Changed the master cylinder and blocked off the 2 speed changer as per JD and bled the system. The clutch feels like its disengaging but it still pulls like the clutch is engaged. Is the disc stuck to the flywheel? Is there another way to fix it other than splitting the tractor and putting a clutch in it? Any help would be appreicated. Thanks, David
davidval
02-12-2003 05:32:42
 Re: 2140 clutch in reply to david, 02-11-2003 12:56:33
check stroke of the rod in the slave cylinder, should be at least 3/8". if less, check again master cylinder, make sure there is some (as little as possible)end play in the operating rod.
if stroke is 3/8" or more, you have a problem within the clutch.
david
